Actions aren’t being triggered in Zabbix 2.0.2
  • johnw230873
    • Aug 2010
    • 54
    I can’t seem to trigger actions from our new Zabbix server that I am building. After finding this issue I have gone right back to the basics trying to get an alert working.
    I have created a new host and all I am doing is pinging it
    Created the ping item and trigger for it
    Next create a simple action
    Once this is all set up I do a simple test of changing the IP of the host to an IP that doesn’t exist
    I also take note of the amount of emails in the Notifications that have been sent to this user.
    When Zabbix can and can't see the Host
    So at this stage I know the host’s trigger is working.
    What I’m not seeing is
    • any email being sent to this user
    • email count going up in notifications
    • under the latest event seeing any Actions taking place
    I don’t believe that this is an email issue as I have auto discovery emails going out to this user fine so unsure what is happening.
    Any ideas where to look here and what I can test (e.g. maybe an action without an email). I’m not the best with Linux but can find my around it.
  • bradh
    • Aug 2012
    • 14
    Admin / Media Types - You have your email server configured? And "Enabled" is checked?
    Admin / Users - If you switch from "user groups" to "users", then select a user (like 'admin'). Then go to the "Media" tab, you have entered an email media type and entered an email address? The status is "enabled" here?
    • johnw230873
      • Aug 2010
      • 54
      Brabh, yes all of these is done as the netowrk decovery emails are working
      • raoul
        • Nov 2011
        • 29
        Re:
        Is email media active in the user's Profile ? (link on top right of each page)
        Cheers,
        y/
        • johnw230873
          • Aug 2010
          • 54
          Yes email is active and working, I think the issue is that the action is not triggering as there is not record of a action taking place.
          If an action took place I should see ever a red or green number under the action field, red for bad outcome, green for good
          example from a bad zabbix server
          example fo a good zabbix server (with a bad mail setup)
          Thanks for the ideas guys
          • Riley69
            • Aug 2012
            • 17
            zabbix alerting not working
            I have the exact same problem. Triggers and actions have been created,but I receive no email notifications. Is there maybe something wrong with my email setup?
            SMTP server:localhost
            SMTP helo :localhost
            SMTP email: [email protected]
            Our company is using Google apps for our emails. Is there any special setup for Google apps to work as I am able to send an email from the zabbix server itself to my Google apps email?
            • asynakie
              • Oct 2012
              • 15
              I had this exact same problem and came across your thread when searching for an answer. My new thread can be found in the link below. I just wanted everyone to know that if you stumble over this thread searching for the same problem, I was able to find a solution.
              The user was a regular admin and for some reason didn't have read / write access to the test group I created, even though it had it for everything else. I made the user a super admin and now I'm getting emails like I should. So go in and check your user permissions first. Make sure the user has read / write access to the group or host that you're trying to get emails from.
              My thread: https://www.zabbix.com/forum/showthr...105#post126105
              • alessandro.silva
                • Feb 2013
                • 22
                Action not defined
                I didn't see nothing action in the screenshot. You have to define a action to the item.
